It is currently Wed Aug 20, 2025 8:51 am
PostPosted: Sun Mar 30, 2014 10:35 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Just getting a feel for what target weights for bridges are out there...not including saddle and pins I'm around 31 grams +\- with ebony.
Doug
PostPosted: Sun Mar 30, 2014 10:44 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
Doug, probably not much help, since I've only been building classicals, but I try to come in around 20 grams using rosewood. Seems like this has been a recommended target in some of the past threads I've read, even for steel strings. Also seems like ebony tends to run a little heavier when people have discussed various woods (e.g., rosewood versus ebony).
PostPosted: Sun Mar 30, 2014 11:46 am
27 gram 6x1-ish ebony bridge on my #2
15ish gram bridge on the little classical I just finished.
I'm thinking of experimenting with cf on my next.
PostPosted: Sun Mar 30, 2014 12:18 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I made a bridge out of African blackwood and it weights like 45 grams... really heavy for sure! The ebony bridge that is slightly thinner (about 1/8" thinner) weights 10 grams less!
Typhoon Guitars
PostPosted: Sun Mar 30, 2014 1:07 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
My madrose bridges weigh in at about 22 grams average.
Mr Gore recommends as light as possible - as low as 15 grams if possible.
PostPosted: Sun Mar 30, 2014 1:21 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I didn't do much about the high weight mostly because an original Gibson SJ300 (or J200) used a really large bridge that is probably heavier... But given the higher density of African blackwood it seems lower density wood would give lighter bridges and therefore better sound..?
Typhoon Guitars
PostPosted: Sun Mar 30, 2014 2:48 pm
First name: Danny
Last Name: Vincent
With my standard belly bridge, the one in the photo, I have a hard time getting the weight of Ebony down below 30g. 31 or 32 for Macassar. Depending on the piece, I can get Brazilian down to about 28g. The last guitar I stung up had Paua Ferro for a bridge. It so far has been the lightest belly bridge I have used at 23g. I think that is going to be a very nice sounding guitar. With a Sitka top, it sounded great right out of the hole.
I'm not sure what the lightest rectangle bridge I've made weighed in at. Sometimes in my haste to get them glued on I forget to weigh them.
PostPosted: Sun Mar 30, 2014 4:24 pm
Never weigh them...
Never found the weight of individual parts makes that much difference. But then, I would guess my tops are 10-20 thou thicker than most of you folks tops, use laminated braces, ladder bracing, and get my sound out of tapping and picking woods that are lively, not light. Always felt that the tone was in the wood, not what you take away and leave as shavings on the floor.
Different strokes...
PostPosted: Sun Mar 30, 2014 4:30 pm
Last Name: Beaver
City: Lake Forest
My last bridge was African blackwood. It came in at 41g. (before the saddle slot was cut. I do that on the guitar)
But then it is the heaviest wood commercially available.
I also use:
BRW about 28g
Bois de Rose about 32g
Amazon RW about 37g
I have yet to figure out how to make a 18 - 20g bridge.
Joe Beaver
Maker of Sawdust
PostPosted: Sun Mar 30, 2014 4:50 pm
Generally been about 20-25 g in EIR, which is all I've used so far in only 6 guitars
Last one was an OLF SJ, as per plan, 21 g before fitting, less pin holes drilled after fitting and some shaving on the guitar, so about 19/20 g.
PostPosted: Sun Mar 30, 2014 6:15 pm
First name: Tom
Last Name: West
State: Nova Scotia
Must say I'm in the same boat, 25g is about the best for me. Might have to try Trevor Gores method. Have used pau ferro for a couple and it's nice wood to work but what I have must be on the heavy end of its scale.
Tom
PostPosted: Sun Mar 30, 2014 6:40 pm
First name: Trevor
Last Name: Gore
City: Sydney
Steel string 15-25 grm. The heavy end is when the owner wants a particular look (e.g. Braz) above other aspects of functionality.
Classical, never more than 15 grm and as low as 10 grm.
http://www.goreguitars.com.au
PostPosted: Sun Mar 30, 2014 8:44 pm
28 g average for me, 1x6" rectangle.
PostPosted: Mon Mar 31, 2014 10:24 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Pau ferro means 'iron wood'. It can be quite heavy.
PostPosted: Mon Mar 31, 2014 11:19 pm
Last Name: Kincheloe
I haven't built enough "normal" guitars to have a good average, but I shoot for around 20g for steel strings, and 15g or less for classicals. 13 string BRW harp guitar bridge came out at 28g, which I think is decent considering the necessary size of it. No ebony for me. I want to try African blackwood sometime though, despite the weight.
The main trick I use to get the weight down is to taper the thickness toward the back end. Only the part in front of the saddle slot really needs to be tall. Everything behind can be a lot thinner and still provide the necessary glue area and plenty of stiffness, especially if you have a bridge plate underneath. Plus if you route the saddle slot first, and then taper from the underside, the saddle slot gets tilted backward a few degrees, which is a good thing.
And don't forget to minimize the weight of the bridge plate as well.
These users thanked the author DennisK for the post: Doug Balzer (Mon Mar 31, 2014 11:23 pm)
PostPosted: Tue Apr 01, 2014 7:02 am
First name: Tom
Last Name: West
State: Nova Scotia
John Arnold:
I was commenting in re: to Danny V. post where he said his lightest bridge was Pau Ferro. What I have is heavy but I did not know the variation within its weight range.
Tom
PostPosted: Tue Apr 01, 2014 9:55 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Mine have been in the mid twenties, using various Ebonys.
PostPosted: Tue Apr 01, 2014 10:42 am
First name: Danny
Last Name: Vincent
Tom West wrote:
John Arnold:
Tom
The boards I have, while still pretty dense, are on the lighter side weight wise. I used a Pau Ferro FB on the same guitar and although I didn't weight it you could feel it being light. I like this Wood Database. http://www.wood-database.com/lumber-ide ... pau-ferro/ I think it provides a pretty good benchmark. I'm not sure but I think the 2 density numbers must be the variation.
PostPosted: Tue Apr 01, 2014 11:40 am
First name: Ringo
For me it depends on what I want tonally... for my normal SS I generally go for lots of volume and a fast response with little care for sustain and shoot for about 20-22g. For a slower attack and decay I want upper 20s... the higher weight brings a tone that blooms relatively slowly and has lower volume. Almost as important as bridge weight is damping which is a whole other discussion.
I have a 17g padauk bridge going on my next, which is braced super light and is as lively a box as I've made. I expect it to be a really loud, punchy, in your face kind of instrument.
PostPosted: Tue Apr 01, 2014 12:19 pm
Tom West wrote:
John Arnold:
I w............................................................................................................................................side weight wise. I used a Pau Ferro FB on the same guitar and although I didn't weight it you could feel it being light. I like this Wood Database. http://www.wood-database.com/lumber-ide ... pau-ferro/ I think it provides a pretty good benchmark. I'm not sure but I think the 2 density numbers must be the variation.
It explains elsewhere on the website
Quote:
The first number is the basic specific gravity, based on the botanical standard of ovendry weight and green volume. The second number is meant for woodworkers, and is simply a snapshot of the wood’s specific gravity at 12% MC, (that is, both 12% MC weight and volume).
Full blurb article is here http://www.wood-database.com/wood-articles/specific-gravity/
These users thanked the author Colin North for the post: DannyV (Fri Apr 04, 2014 8:16 am)
PostPosted: Wed Apr 02, 2014 11:50 am
First name: Tom
Last Name: Phillips
City: Arcata
I'm around 31 g with a Honduran belly bridge. I think my last two were 32 and 33 g. Surprising how much material you have to remove to lose a gram or two...
PostPosted: Thu Apr 03, 2014 8:39 pm
Bridges need to be a little heavier than this ...
These users thanked the author Jim Watts for the post (total 2): Haans (Fri Apr 04, 2014 7:49 am) • Imbler (Thu Apr 03, 2014 9:18 pm)
